New Internal SIP addresses and a great SIP client for iPhone and Android
**Now anytime anyone calls your FlyNumber you can answer the calls for free with unlimited incoming minutes on your iPhone or Android, when you make an outgoing call you’ll pay ourlow per minute rate and have your FlyNumber show up as the Caller-ID. **
This has been the most anticipated feature coming out of our PBX/ Virtual Phone System; it will enable you to register a SIP device/client with our own internal SIP addresses. No need to use a 3rd party VOIP provider, just choose a phone number and send the calls to our “PBX”. You’ll have the ability to register multiple devices and use our legendary PBX Grid to configure your configuration. It’s never been easier to make and receive phone calls with your FlyNumber.
The Caller-ID feature is also pretty neat. You’ll have the standard feature where you can assign a FlyNumber to an outgoing caller ID for a SIP account. So for example: you call out on SIP account A your UK number shows up as the outgoing caller ID and when you make an outgoing call on SIP account B your Spain Phone number shows up as the caller ID. Well ,what happens if you have multiple international FlyNumbers and call all over the place but want to deal with just 1 SIP account?… we got you covered.
This new never before seen feature will allow you to call anywhere in the world and have the correct Caller- ID show up depending on which country you dial . For example, you have a Brazil, Canada and USA FlyNumber, when you call any USA phone number your USA FlyNumber will appear on the caller ID, the same goes for when you call a Brazilian phone number- your Brazil FlyNumber shows up as the Caller- ID.
How to Setup with a SIP client on your iPhone or Android phone
My new favorite SIP client is the Acrobits SIP client for iPhone and Android – $6.99 and worth every penny. If for no other reason, buy the app for its ability to receive phone calls while being completely off. The number one issue with many other SIP clients is battery life; you need to keep the app running in the background to receive phone calls. Not here, if you’re not making outgoing calls at the moment just shut down the app and you’ll still receive the phone calls via push notifications.
First you need to get the SIP account from your PBX/ Virtual Phone System on your FlyNumber Account. Log on to your PBX Grid and drag a “Persons” module onto your grid, Enter a name> and then choose VOIP > Device.
It then displays your SIP credentials( as seen below) , keep in mind it’s not active until you save and finish creating the module.
Here is how that information looks on the Acrobit “Generic SIP Account” setup. Pretty simple.
Here ‘s a screenshot of my configuration in the FlyNumber PBX, I have the 347 Phone number attached to my SIP account, and if I don’t answer it goes into voicemail.
The only setting you may want to tinker with on the app are the codecs, especially if you experience issues. Try keeping G711 ulaw as the preferred code
