Audio Playback
The Audio Playback module lets you play pre-recorded messages or music to your callers. This is perfect for:
  • Welcome messages
  • After-hours announcements
  • Hold music
  • Custom greetings before connecting to a Ring Group
  • Error messages in your IVR system
Setting It Up​
The Audio Playback module is straightforward to configure:
  1. Name: Give your audio playback a descriptive name that helps identify its purpose, such as:
    • "Welcome Message"
    • "Holiday Hours"
    • "Support Queue Music"
  2. Audio File: Select or upload the audio file you want to play:
    • Manage your audio files in the Audio Files menu
    • Upload new files or record directly in the system
    • Supported formats: .mp3, .wav, .flac, .ogg
Audio file management interface
Audio File Management
You can:
  • Upload existing audio files
  • Record new messages directly
  • Create playlists for longer sequences
  • Preview files before using them
How It Works​
After playing the selected audio file, the module automatically forwards the call to the next connected module. This allows you to:
  1. Play a greeting message
  2. Then forward to a department
  3. Or connect to another module for further call processing
Practical Example​
Audio Playback usage example
In this example:
  1. A call comes in through a phone number
  2. The Audio Playback module plays a welcome message
  3. The call is then forwarded to a specific team member
Common Uses
  • Welcome messages before connecting to an IVR menu
  • Department-specific greetings before ring groups
  • Holiday or special event messages
  • Queue position announcements
Best Practices
  • Keep messages clear and concise
  • Use professional voice recordings for business messages
  • Test audio quality before deploying
  • Consider different language options if needed
  • Update seasonal messages regularly
