Modules Overview
Modules are the essential components that power your phone system. Think of them as building blocks that you can connect together to create your perfect call flow. Each module handles a specific task - from receiving calls to playing messages or routing callers to the right department.
Example of expanded and collapsed modules showing configuration details
Quick Setup
When you drag a module onto your workspace, a setup window appears automatically. Fill in the required settings and click Save to activate your module. Not ready to set it up? Click Cancel and the module will be removed, keeping your workspace clean and organized.
Managing your modules is straightforward:
  • Click once to expand and see what's inside
  • Look for the gear icon (⚙️) when you need to change settings
  • Modules connect together to build your call flow
